60
Get value of boolean column in web combo
Hello
I am having some trouble retrieving the value from a boolean column in my webcombo. The value is always returned as TRUE.
I have stepped through the code that populates the webcombo and the column definately contains some FALSE values.
Below is my code. I am doing validation on the client side. The user has selected a row in a webcombo and I want to get the value of one of the columns in the selected row. The column is a boolean column. My code is as follows:
var workTypeCombo = igcmbo_getComboById("cmbWorkType");
var workNoteReqd = workTypeCombo.getGrid().Rows.getRow(workTypeCombo.getSelectedIndex()).getCellFromKey("WorkNoteReqdFlag").getValue();
var workNote = document.getElementById("WorkNote");
if (workNoteReqd == true && workNote.value == "")
errorMessage = errorMessage +
"A Work Note must be supplied for the selected Work Type.<br/>";
Has anyone else had this problem? What am I doing wrong?
Your help would be much appreciate.
