45
Setting input focus and cursor to a Webcombo (7.3) after load
After binding the source data to the Webcombo, I am unable to set the input cursor in the text portion of the control. The control's editable property is set to 'True.' The contol's Focus() method has no effect. I will assume that one should use the client side InitializeCombo event to do this. My intent is to have the input cursor  immediately available so the user does not have  to tab into or mouse click into the text field in order to edit. If the solution is to use javascript in the InitializeCombo event, please provide an example of the script. Thank you.
