I use UtraWebGrid and in one of the column, i have buttons use for update the SQL database with any change in that row. My problem is on the click event:UltraWebGrid1.DisplayLayout.ClientSideEvents.ClickCellButtonHandler
How do i write a javascrip to connect to the SQL database and update the database with the change that user edit in that row.
Any help is greatly appreciated.
Ddee
ClickCellButtonHandler takes GridName and CellId.
by cell ID you can get row and its data.
add an asyn call to the server pass the data and it should save that.
or you can implement webservice to save this data.
