100
UltrabWebToolbar doesn't work with updateprogress
Hi guys,
 My aspx page has a ultrawebtoolbar(with 3 buttons) and others asp.net controls(dropdowns, text, buttons, updatepanels). The problem appear when I put an updateprogress (Ajax Extension)  on the page. Then, at run-time the event ButtonClicked of the ultrawebtoolbar doesn't work :S
 I'm using netadvantage 2006.2 CLR 2.0, ASP.NET 2.0
Thanks in advance.
Talo
Peru
  • 45049
    This sounds like it may be a bug.  However, NetAdvantage for .NET 2006 Volume 2 is no longer eligible for maintenance, so no new bug fixes are being applied to this version.
    I suggest that you test this with the latest hot fix for NetAdvantage for .NET 2006 Volume 2.  The issue may or may not be fixed there.  If it is not, then see if you can reproduce the problem with a more recent release of the toolset, and if you can, then please submit a support request so that we can investigate in depth and fix in the versions of the toolset that we are currently maintaining.
