We are using Infragistic UltraWebGrid Ver 7.1 in our Application. Pagesize of the grid is 20 rows per page. we have a vertical scroll bar for the web grid and without scrolling we can see 10 rows and if we need to see other rows we need to scroll the scrollbar and Its working fine in vs2005. But now we moved our application to vs2008. After moving to vs2008 when the we grid loaded we can see all the 20 rows and all the rows after 10 is came out of the web grid Layout(its overlaping the other ctrls on the bottom of the page) and the scroll bar is not working. What should i do for resolving this issue?? Pls help me...
Pulikkan
same problem has been faced by me... :(
Thanks for the reply Alex,
I am using the ContentTemplate in my tabs. I tried adding a contentPane and set the property you suggested and I am still getting the same result. I will try a couple more things and post back here.
Patrick
I am seeing a similar problem with my webgrid that is within a tab control. If the page is not maximized and you select a row, and then maximize the page, the rows jump outside the grid. I have no idea what is causing the problem. I am sending a video of the problem to dev support.
Pat
