I'm using UltraWebGrid 6.3 with ASP.Net 2.0. However, I can Not Select / Copy cell text from a cell at all. Is there any property in the ultrawebgrid which enables select/copy cell text?
hi,
I am using infragistics grid in my application. Where in any browser user cannot select the text in the columns of the Grid with the mouse and copy the text to the clipboard using ctrl+c or copy by right click using mouse. But I need solution to allow user to select text in grid. So can any one give solution for this.
Thanks in advance
Karthick
To limit input to numbers only, you need to drop a WebNumericEdit control on the form and set its ID to the column's EditorControlID property, at the same time column's Type property should be set to ColumnType.Custom.
If you look at the sample, it uses UltraWebMenu, which is opened on the right click over the grid. You need to add the same logic to your application.
Also, what do I need to do if I need to limit my cell text to numeric?
Presently, it accepts alphabets too.
On my web page, when I click on right any cell of my grid, I cannot see any Copy-Paste option.
I only see the web options i.e. the options which I see when I right click on any area of the web page.
