Is there any way (property) in WebCurrencyEdit that if user enters -45 WebCurrencyEdit will convert it to +45 and not 0 if I have put MinValue="0"
I tried with InvalidValue event handler, it sets the value but it is not showing on screen. I mean it if I call obj.setValue(obj.getValue() * -1) which will convert it to +ve it sets the value if I debug and check for getValue() but onscreen it shows $0.00.
I tried with ValueChange event by changing MinValue="-99999..." but then the problem is when I enter -45 1st time it converts it to 45 correctly but if I enter same number -45 again then event id not getting fired and it shows ($45.00) for -ve value.
any suggestions...???
Thanks.
Hi Anand,
If you want to modify value within InvalidValue event, then you should use fields param in handler. It has 3 members: type, text and value.
If type is 1, then it is invalid range. The text contains current text in editor and value contains suggested new/replacement value. If you do not like that value, then you may set your own and that will be used instead of suggested. Example:
function WebCurrencyEdit1_InvalidValue(oEdit, fields, oEvent){ var text = fields.text; if(type == 1 && text && text.charAt(0) == '-') fields.value = parseFloat(text.substring(1));}
Thank you very much that halped.
