Can some one help me in solving the below issues?
We got these errors after migrating the .NET project from 1.1 to 2.0.
Any help is really appreciable,its ver urgent for us to solve these issues.
1)In our application we are displaying the selected filters in the grid which is Infragistics Web Grid.
The font is looking large when compared to that of 1.1 application.
2)We are getting this error with the style tag-Text is not allowed between the opening and closing tags for element Style.
In our application we are not referring the new NetAdvantage 2008 Volume 3 DLLs.
One more point I wuold like to add- we are using Infragistics 4.3 version even after migrating to 2.0.
I don't suggest using NetAdvantage 2004 Volume 3 in a .NET 2.0 project. This version of the toolset was only supported with versions 1.0 and 1.1 of the .NET Framework. You may simply be hitting a point where the toolset becomes incompatible with the framework. You might also be hitting a bug, but since this version of the toolset is retired, no new bug fixes are being created for this version and no official support is available.
Does the problem persist if you use a more recent version of the toolset? If not, then that means it was either a simple incompatibility or a bug we've since fixed. If so, then you can submit a support request and provide us with more information so that we can look into it further.
We have migrated our application from .NET 1.1 to .NET 2.0 but we are referencing the old DLLs of Infragistics 2004 version. We are using Infragistics ultrachart ,it is throwing error -"Page.RegisterRequiresPostBack can only be called on controls that implement IPostBackDataHandler"
So I had run the "Project Upgrade Utility" ,after running this I closed my application and removed the DLLs in the aplication BIN folder.
I build my application again ,now it is giving this error- "The type or namespace name 'BorderDetails' does not exist in the namespace 'Infragistics.WebUI.Shared".
I have removed the DLL 'Infragistics.WebUI.Shared" and added it again ,still the above error is coming..
Any help is really appreciable as it is urgent for us.
Usha.
This looks like a familiar issue when trying to use older versions of the toolset in a .NET 2.0 (or later) application. The only way I know of to get around this issue is to upgrade to a version of the toolset that is supported with the version of the .NET Framework you're using; the assemblies from NetAdvantage 2004 Volume 3 (or volumes 1 or 2) won't necessarily work in a .NET 2.0 application.
I upgraded the .NET 2.0 application with the newer version of Infragistics -NetAdvantage_ASPNET_20083_CLR20,
I am getting different errors:
Line 909: #line 69 "D:\IM\MigrationProject\IMDOTNET\WebUserControlFilter.ascx
I have posted this with support team also,Sarita responded to this.
I need some information,Can we have a Net Meeting with the support team? If so could you please provide us the details like Email and Phone number?
