20
WebTree Check All Child Nodes With Demand Load
We have a web tree and want to give the user the ability to check the parent node and have it automatically check the child nodes.  The only problem is that we are using demand load.  We can get around most issues except for the following scenario:
  1. Create a tree that has a parent, children, and grandchildren and uses demand loading and has checkboxes next to each node
  2. Expand the parent by clicking the plus sign
  3. Check the box next to the parent
We have JavaScript like in the example given at http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=4941.  The only thing we added was "if (bCheck && !childNodes[n].getExpanded()) { childNodes[n].setExpanded(true); }".  This way we will expand the children to expose the grandchildren (since they are only loaded on demand).  On the server side DemandLoad event we check if the node is checked and if so, raise the OnDemandLoad(NEWLY_ADDED_NODE) method off the web tree so we load all the child nodes down the chain.  The problem is that when we are in the DemandLoad server-side event, it doesn't recognize that the node has been checked.
Any help would be greatly appreciated.  Thanks
