<ig:gridEditing id="#{tab}GridEditing" enableOnMouseClick="single" editMode="cell"
cellValueChangeListener="#{transacBean.onCellValueChange}" />
<ig:columnSelectRow id="#{tab}SelectRow" showSelectAll="true"></ig:columnSelectRow>
Then the grid will not be refresh.
old posting:
<form id="idCaseTransactionTestForm" name="CaseTransactionTestForm">
<input type="submit" value="submit"/>
<ig:gridView id="idGridView" dataSource="#{transacBean.caseTran}" binding="#{transacBean.gridView}"
columnHeaderStyleClass="gridHeader" styleClass="ccTextSytleClass" rendered="true" >
</ig:gridView>
</form>
the event handler onSelectedRowsChange() will not be called if you select rows. If the submit button is pressed, the page will be submitted and the view will be refreshed.
Trying to get onSelectedRowsChange() called, I use
<h:form>
<gridView ..../>
</h:form>
http://java.sun.com/jsf/html
The event handler onSelectedRowsChange() will be called correctly, but the page will not be refreshed even the backing bean is called, it shows the initial data.
The problem exists for other ig controls. It doesn't refresh or event handler doesn't got called. Please help.
Thanks.
Hi yzbythesea, We are glad sample application worked for you. Yes!! We can definitely refresh grid from any of the functions in the backing bean. Greatly appreciate if you could log to ‘Support Requests’ and please provide us an isolated sample application. We shall provide solution at the earliest.
Note: DataBind() could be also applied to any other Infragistics components i.e. Tree, Menu etc.
Also, Please visit below link containing many interesting and challenging sample applications (NetAdvantage for JSF) with source code.
http://www.componentsforjsf.com/IGJavaWebSite/faces/home.jsp
Thank you!
Hi Swatha,
I tried your approach and it worked!
It seems to me DataBind() is powerful function. Can I refresh grid from backing bean by using DataBind() or other functions? In my case, the backing can be called to other function asking to refresh grid with some new data. I have not found a way to do it.
Thanks a lot.
Hi yzbythesea , Attached below is the sample GridView application. In order to refresh grid we need to call 'grid.dataBind()' in our backing bean under action method.
1) gridReload.jsp
<%@ page language="java" contentType="text/html; charset=ISO-8859-1" pageEncoding="ISO-8859-1"%>
<%@ taglib prefix="ig" uri="http://ko.infragistics.com/faces/netadvantage" %> <%@ taglib prefix="f" uri="http://java.sun.com/jsf/core"%><%@ taglib prefix="h" uri="http://java.sun.com/jsf/html"%>
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"><html><head><meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"><title>Grid Reload Example</title></head><body> <f:view> <h:form> <ig:gridView binding="#{gridReload.grid}" dataSource="#{gridReload.gridData}" styleClass="gridView" dataKeyName="email" selectedRowsChangeListener="#{gridReload.onSelectedRowsChange}" pageChangeListener="#{gridReload.onPageChange}" pageSize="5"> <ig:column resizable="true"> <h:outputText value="#{DATA_ROW.lastName}"></h:outputText> <f:facet name="header"> <h:outputText value="Last Name"></h:outputText> </f:facet> </ig:column> <ig:column resizable="true"> <h:outputText value="#{DATA_ROW.firstName}"></h:outputText> <f:facet name="header"> <h:outputText value="First Name"></h:outputText> </f:facet> </ig:column> <ig:column resizable="true"> <h:outputText value="#{DATA_ROW.email}"></h:outputText> <f:facet name="header"> <h:outputText value="Email"></h:outputText> </f:facet> </ig:column> <ig:column resizable="true"> <h:outputText value="#{DATA_ROW.phone}"></h:outputText> <f:facet name="header"> <h:outputText value="Phone"></h:outputText> </f:facet> </ig:column> <ig:column resizable="true"> <h:outputText value="#{DATA_ROW.type}"></h:outputText> <f:facet name="header"> <h:outputText value="Category"></h:outputText> </f:facet> </ig:column> <ig:column resizable="true"> <h:outputText value="#{DATA_ROW.salary}"></h:outputText> <f:facet name="header"> <h:outputText value="Salary"></h:outputText> </f:facet> </ig:column> </ig:gridView> <h:commandButton action="#{gridReload.action}" value="Click"/> </h:form> </f:view>
</body></html>
2) CustomerSimpleGridWithRowSelectionPageBean.java
package com.infragistics.gridreload;
import java.util.ArrayList;import java.util.Iterator;
import javax.faces.component.UIOutput;import javax.faces.context.FacesContext;
import com.infragistics.faces.grid.component.GridView;import com.infragistics.faces.grid.component.RowItem;import com.infragistics.faces.grid.event.SelectedRowsChangeEvent;import com.infragistics.faces.shared.event.PageChangeEvent;import com.infragistics.faces.shared.smartrefresh.SmartRefreshManager;import com.infragistics.gridreload.GridDataDAO;
public class CustomerSimpleGridWithRowSelectionPageBean { GridDataDAO data; //Components for binding. GridView grid; UIOutput showSelected; boolean dat = true; public ArrayList getGridData() { // This is the simplest method for retrieving data. // We check to see if data is null, in case its being // held in the session. if(dat){ if(data == null) data = new GridDataDAO(); return data.getGridData(); }else { if(data == null) data = new GridDataDAO(); return data.getGridData2(); } } public String action() { System.out.println("action method called"); if(dat) dat = false; else dat = true; grid.dataBind();
return "success"; } public void onSelectedRowsChange(SelectedRowsChangeEvent event) { System.out.println("onSelectedRowsChange fired"); } public void onPageChange(PageChangeEvent event) { System.out.println("onPageChangeListener fired"); }
public GridView getGrid() { return grid; }
public void setGrid(GridView grid) { this.grid = grid; }
public UIOutput getShowSelected() { return showSelected; }
public void setShowSelected(UIOutput showSelected) { this.showSelected = showSelected; }
public boolean isDat() { return dat; } public void setDat(boolean dat) { this.dat = dat; } }
3) EmployeeBean.java
public class EmployeeBean {
private String firstName, lastName, email, phone, type; private int recordCounter; private float salary; private String bgColor;
public EmployeeBean() { }
// This non-standard bean constructor is inserted to
// simplify the example code.
public EmployeeBean(int recordCounter, String firstName, String lastName, String email, String phone, String type, float salary ) {
this.recordCounter = recordCounter; this.firstName = firstName; this.lastName = lastName; this.email = email; this.phone = phone; this.type = type; this.salary = salary; }
public String getFirstName() { return firstName; }
public void setFirstName(String firstName) { this.firstName = firstName; }
public String getLastName() { return lastName; }
public void setLastName(String lastName) { this.lastName = lastName; }
public String getEmail() { return email; }
public void setEmail(String email) { this.email = email; }
public String getPhone() { return phone; }
public void setPhone(String phone) { this.phone = phone; }
public int getRecordCounter() { return recordCounter; }
public void setRecordCounter(int recordCounter) { this.recordCounter = recordCounter; }
public String getType() { return type; }
public void setType(String type) { this.type = type; }
public String getBgColor() { if (type.equalsIgnoreCase("hourly")) return "#FFCCCC"; else if (type.equalsIgnoreCase("salaried")) return "#CCCCFF"; return "white"; }
public void setBgColor(String bgColor) { this.bgColor = bgColor; }
public float getSalary() { return salary; }
public void setSalary(float salary) { this.salary = salary; }
4) GridDataDAO.java
import com.infragistics.gridreload.EmployeeBean;
public class GridDataDAO {
private ArrayList data; private ArrayList data2;
public GridDataDAO() {
data = new ArrayList(); data2 = new ArrayList();
data.add(new EmployeeBean(1, "John", "Smith", "jsmith@abc.com", "555-1234", "hourly", 25000.00F)); data.add(new EmployeeBean(2, "Jane", "Doe", "jdoe@def.com", "555-4321", "salaried", 35000.00F)); data.add(new EmployeeBean(3, "Bob", "Green", "bgreen.fre.com", "555-1324", "hourly", 45000.00F)); data.add(new EmployeeBean(4, "Sally", "Brown", "sbrown.wsx.com", "555-0897", "hourly", 80000.00F)); data.add(new EmployeeBean(5, "Joe", "Armstrong", "jarmstrong@rfv.com", "555-4653", "salaried", 65000.00F)); data2.add(new EmployeeBean(6, "Bill", "Feldman", "bfeldman@rfv.com", "555-0098", "hourly", 25000.00F)); data2.add(new EmployeeBean(7, "Victor", "Joy", "vjoy@tgb.com", "555-7890", "salaried", 100000.00F)); data2.add(new EmployeeBean(8, "Martin", "Chase", "mchase@ujm.com", "555-1123", "salaried", 90000.00F)); data2.add(new EmployeeBean(9, "Steve", "Short", "sshort@mju.com", "555-0765", "hourly", 55000.00F)); data2.add(new EmployeeBean(10, "Alice", "Baker", "abaker@plm.com", "555-1029", "salaried", 120000.00F)); }
public ArrayList getGridData() { return data; } public ArrayList getGridData2() { return data2; }
public ArrayList getHourly() { ArrayList x = new ArrayList(); int i = 0; while (i < data.size()) { if (((EmployeeBean) data.get(i)).getType().equals("hourly")) x.add(data.get(i)); i++; }
return x;
public ArrayList getSalaried() { ArrayList x = new ArrayList(); int i = 0; while (i < data.size()) { if (((EmployeeBean) data.get(i)).getType().equals("salaried")) x.add(data.get(i)); i++; }
return x; }
