I Want to use validatorcallout extendor with Infragistic webdataedit controls
can any one tell me how i can use it , because i tryed it but error massage popup at wrong place
I found the solution. It looks like with Infragistics 2012, the control has ":v:" after it. So I just updated Client\MicrosoftAjax.Extended\ValidatorCallout\ValidatorCalloutBehavior.pre.js with the following change:
var elementToValidate = this._elementToValidate = $get(elt.controltovalidate.replace(":v:", ""));
Now the ValidatorCalloutExtender appears in the proper position.
I tried that too but it didn't work. I downloaded AjaxControlToolkit.Source.zip file from:
http://ajaxcontroltoolkit.codeplex.com/releases/view/65800
Do you what else I need to change?
Trent
Hi Trent,
You probably refer to difference between old WebMaskEdit and new WebMaskEditor controls. Those are completely different controls, though, they use similar functionality.
I guess in your codes you should remove prefix "igtxt" and use something like
elem = $get(elt.controltovalidate);
It looks like in Infragistics 2012, the hidden fields does not begin with "igtx" anymore. So now the message appears in the upper left corner again.
Infragistics 2009 source code for masked editor field: (working properly)
I found the solution at http://robrich.org/archive/2008/03/27/validator-callout-doesnt-display-on-second-control-after-fixing-first.aspx.
