185
Error when removing row from a grid with groupby
I am using WebGrid version 8.2.20082.1000 with LoadOnDemand set to xml and viewtype set to OutlookGroupBy. The ASP.NET page has menu buttons where a user can select one or more rows from the grid and click the 'Delete' button. In the code behind I am using the following statement inside a for loops that iterates through the selected rows collection.
uwgEmployees.DisplayLayout.Rows.Remove(row)
Everything works fine except when a user does a group by on the grid and then tries to delete selected rows. In this event the call to remove throws an exception. What is the correct method of removing selected rows from the grid?
 Thanks!
