20
regarding tab focus
I have a tab control with three tabs
There is a mandatory field in tab1.
If we select tab3 and click on the button in tab3 it is display a message that mandatory fields requires input
Now is there any way to change the focus from tab3 to tab1 automatically because the mandatory field is in tab1
  • 185
    Hi RamaKrishna,
    Assuming that there is a textbox in the first tab; to make the selected tab to be the first tab if the text of the textbox is null even if we click other tabs, the following code should help :
    protected void UltraWebTab1_TabClick(object sender, WebTabEvent e)
    TextBox tb = this.UltraWebTab1.Tabs.GetTab(0).FindControl("TextBox1") as TextBox;
    if (tb.Text == "")
    this.UltraWebTab1.SelectedTabObject = this.UltraWebTab1.Tabs.GetTab(0);
