150
How to populate Tree using XSL?
I am using XSL to populate XML data in a Tree. It works well, however, the documentation seems to be limited and I can't figure out how to set the attributes of the Node. For instance, in the below code snippet, I am trying to set the attribute "ImageUrl" so that the tree will have custom icons, but it isn't working. Where can I find all the different attributes for the databinding Node.
Girish
<xsl:stylesheet  ...
<xsl:template match="/">
  <IGTree>
     <Nodes>        <xsl:apply-templates select="Message" />
    </Nodes>
  </IGTree>
</xsl:template>
<xsl:template match="Message">
   <Node ImageUrl="Images/File.gif">
      <Text><xsl:value-of select="@Name"/></Text>
   </Node>
</xsl:template>
</xsl:stylesheet>
  • 7694
    Please take a look at the link below
    http://samples.infragistics.com/2008.3/WebFeatureBrowser/contents.aspx?showCode=True&t=WebTree/treexsltransform/TreeXslTransform.aspx~srcview.aspx?path=../webfeaturebrowservb/WebTree/treexsltransform/TreeXslTransform.src~srcview.aspx?path=WebTree/treexsltransform/TreeXslTransform.src
    Hope this help.
    Thanks.
