70
Send Data from WebGrid or UltraWebGrid to DB SQL Server 2005
Dear All:
 Please can anybody help me to write a easy code to send changes of webgrid or ultrawebgrid to Sql Server 2005 Express ???
 i wrote the follwoing code but nothing changes ?!!
Imports System.Data
Partial Class _Default
Inherits System.Web.UI.Page
Private dataConnection As New SqlClient.SqlConnection("Data Source=BASHEER-PC\SQLEXPRESS;Initial Catalog=Equipments;Integrated Security=True")
Private c_dataAdapter As New SqlClient.SqlDataAdapter
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
c_dataAdapter = New SqlClient.SqlDataAdapter("SELECT Project_ID,Project_Name,Region FROM Projects", dataConnection)
' create insert, delete and update commands
Dim dataCommandBuilder As New SqlClient.SqlCommandBuilder(c_dataAdapter)
c_dataAdapter.InsertCommand = dataCommandBuilder.GetInsertCommand
c_dataAdapter.DeleteCommand = dataCommandBuilder.GetDeleteCommand
c_dataAdapter.UpdateCommand = dataCommandBuilder.GetUpdateCommand
' create temporary datatable
Dim tempDataTable As New DataTable("Projects")
c_dataAdapter.Fill(tempDataTable)
' bind datatable to UltraGrid
UltraWebGrid1.DataSource = tempDataTable
UltraWebGrid1.DataBind()
End Sub
Protected Sub Save_Data()
' get reference to grid datasource
Dim gridDataTable As DataTable = UltraWebGrid1.DataSource
' test for valid grid datasource
If gridDataTable Is Nothing Then Exit Sub
' send changes to database
c_dataAdapter.InsertCommand.Connection = dataConnection
c_dataAdapter.DeleteCommand.Connection = dataConnection
c_dataAdapter.UpdateCommand.Connection = dataConnection
c_dataAdapter.Update(gridDataTable)
End Sub
Protected Sub Button1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Button1.Click
Call Save_Data()
End Sub
End Class
this code worked very good in windows forms but not worked in ASP.NET 3.5 and no error apeared just without saving data to database.
Please help me. >>>
Best Regards
Basheer Massarrani
Civil & Electro Mechanical
KSA-Jeddah
