235
Ultrawebgrid loses style in WARP
I have a problem with style of the ultrawebgrid placed inside the WARP...I have two WARPs, one contains ultrawebgrid and 'Update' button. For the second panel I set TriggerPostBackIDs property to Update button id. When the user clicks 'Update', second panel is correctly refreshed, however content of the ultrawebgrid loses its styles (or changing to other I don't know about). This happens only once, when panel with grid is refreshed everything backs to normal..
Thanks Bartek
  • 14049
    Is this an option for you to switch to using Application Styling? If yes
    then you could delete all of the styles off grid and the styles will be
    coming from the css files provided by the application styling.
    Another option would be moving all of the style into a css file and have
    it always referenced in the element.
