140
How can i Hide a menu item in WebListBar
  • 4493
    Hello sapineni,
    If you are talking about setting some property like "Visible", there is no such property. However you can programatically set the entire group to be either Disabled (this.UltraWebListbar1.Groups[0].Disabled = true;) or Expanded (this.UltraWebListbar1.Groups[0].Expanded = true;). also you can set Enabled property to false for the item you want to "hide" (this.UltraWebListbar1.Groups[0].Items[0].Enabled = false;). Unfortunatelly the ony way to remove entirely an item is to remove it from a collection.
    Hope this helps.
