I am using a amount column in Webgrid.
I want to put a validation to the column so that it accepts only integer values.
Also i want to display proper message to user when he enters invalid data ex- alphabets,spl chars etc.
How can i achieve this ?
in the exit mode check which is source element from event. if its not 3rd column the return.
for checking value you can do this.
try{
int.parse(value);
catch (e) { show your msg; }
Thanks a lot for the solution.
But i am facing 2 new problems now.
1) how to check the newValue is integer or not at client side?
2) this validation gets applied to all coulmns. i want it only for the Amount column i.e the 3rd column on the grid.
grid_BeforeExitEditModeHandler(gridName, cellId, newValue)
if (newValue is Interger value)
return 0; //Valid
else
return 1; //Invalid
Hope this helpfull.
I forgot to mention that "Amount" column is created dynamically in initialize layout.
