hi..
how to use ultrawebmenu.. i added menu items in quick designer, but it doesnt shows in master page..
help me.........
Hi again,
You can look at: https://ko.infragistics.com/samples/aspnet/data-menu/themes
It is under "WebMenu" -> Menu styles.
You can also use the AppStylist for ASP.NET to make your own styles.
cant get menu design tutorials
You can browse our online samples at: https://ko.infragistics.com/samples/aspnet
There also you can browse the source for each sample.
Hello again,
The best way to start is at our Online Samples site: https://ko.infragistics.com/samples/aspnet
Particulary for WebMenu you can find a sample here: https://ko.infragistics.com/samples/aspnet/data-menu/themes
You can browse sources as well.
