660
How can I retrieve database fields for each level from Web Tree?
Hi
I want to know how can I retrieve database fields for each level from Web Tree.  for example I have a webTree control with 3 levels.  This is bound to the database as follows:
dsmain.Relations.Add("BPSec",
dsmain.Tables["BP"].Columns["bp_id"],
dsmain.Tables["Sec"].Columns["bp_id"]);
dsmain.Relations.Add("SecMR",
dsmain.Tables["Sec"].Columns["sec_id"],
dsmain.Tables["MR"].Columns["sec_id"]);
this.treeMain.Levels[0].LevelKeyField = "name";
this.treeMain.Levels[1].LevelKeyField = "name";
this.treeMain.Levels[2].LevelKeyField = "approved_ts";
this.treeMain.Levels[0].LevelImage = "ig_treeNews.gif";
this.treeMain.Levels[0].RelationName = "BPSec";
this.treeMain.Levels[0].ColumnName = "name";
this.treeMain.Levels[1].RelationName = "SecMR";
this.treeMain.Levels[1].ColumnName = "name";
this.treeMain.Levels[2].ColumnName = "approved_ts";
this.treeMain.DataMember = "BP";
this.treeMain.DataSource = dsmain;
this.treeMain.DataBind();
_________________________________________________________
It works fine.  So, now for example if I click on the 3rd level in the tree, how do I retrieve all the corresponding values from the tree object?  I would need the ID of the first level, ID of the second level, and ID of the third level at a minimum.  Can I just use some format like :  treeMain.nodes.levels[3].fields["ID"]....... or something similar like that?  I am hoping it is this easy.  I took a look at the documentation, but couldn't find a clear indication of what objects I would need to get the desired values.
Thanks!
