I am using ultra web grid
Just stuck in a simple issue i belive.
I am adding data rows to the grid on the button click.
I have my grid inside on of the tables rows as:
<table width="100%"> <tr> <td style="width:28%">
<igtbl:UltraWebGrid................ my grid
</igtbl:UltraWebGrid> </td></tr>
Now my problems is the UI shows 10 rows on the grid and after that when I click button again it keeps on adding the rows but overlaps my table aboveor anything else that is above and I can't even scroll though the data.
Pls sugges
Ideally that should solve the problem. Otherwise try putting following code in codebehind:
ultrawebgrid1.Height = 500;
ultrawebgrid1.DisplayLayout.StationaryMargins = Infragistics.WebUI.UltraWebGrid.StationaryMargins.Header;
i already set the height but same issue
Specify Height attribute to UltraWebGrid
<igtbl:ultrawebgrid id="ultrawebgrid1" runat="server" Width="100%" Height="200px">
