I'm looking for the best way to apply a row style onmouseover and then replace the alternate row styles onmouseout. In an asp.net Gridview I was able to add onmouse attributes at databinding with the row colors set programatically but I don't seem to be able to do that with the webgrid.
I've got some javascript that extracts the row index from the ID but I wonder if there is a better way?
Thanks in advance!
Current Javascript code:
function UltraWebGridRow_Over(gridName, Id, objectType) { try { var Row = igtbl_getRowById(Id); var RowIndex = Row.Id.replace(gridName + "_r_",""); setRowColor(Row, "in", RowIndex); } catch (e) { } } function UltraWebGridRow_Out(gridName, Id, objectType) { try { var Row = igtbl_getRowById(Id); var RowIndex = Row.Id.replace(gridName + "_r_",""); setRowColor(Row, "out", RowIndex); } catch (e) { } } function setRowColor(Row, Direction, RowIndex) { var sColor = "#ffffcc" if (Direction == "out") { if (RowIndex % 2 == 0) { sColor = "white"; } else { sColor="#EFF3FB"; } } var cells = Row.getCellElements(); for (var i = 0; i < cells.length; i++) { cells[i].style.backgroundColor = sColor; } }
Joshua_dev said:Vince did mention that we could single out the header row and apply a specific style...Will it be possible to identify sortable columns and apply a style to the headers of those columns alone???
To identify a sortable column, get a JavaScript reference to the appropriate Column object, and look at the HeaderClickAction property of that column. A value of 2 means SortSingle, while a value of 3 means SortMulti, both of which imply a sortable column. The other values (0 for None and 1 for Select) mean that the column is not sortable.
hi there,
I use style and hoverstyle attributes to switch styles between normal and hover states by assigning cssclasses to each of them.
Thank you!
This is the general approach I would use. You might be able to apply CSS styles instead of specific, hard-coded background colors, but the general approach remains the same.
As a suggested refinement, you can get the index of the row off our client-side Row object, rather than parsing the index out of the row's ID. You can also check to make sure that you have a cell, rather than a column header. Below is a modification of your MouseOver event handler; similar changes can also be made to the MouseOut event handler:
function UltraWebGridRow_Over(gridName, Id, objectType) { if (objectType == 0) // cell { try { var Row = igtbl_getRowById(Id); //var RowIndex = Row.Id.replace(gridName + "_r_",""); var RowIndex = Row.getIndex(); setRowColor(Row, "in", RowIndex); } catch (e) { } } }
