264
Treeview from SQL Reporting Services..
I am trying to build a tree view from Reporting Sevices (I have added a reference to my web app for Reporting service).
I have the following code:
Protected Sub uwtReportFolders_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles uwtReportFolders.LoadDim rs As ReportingService2005
uwtReportFolders.Nodes.Clear()
rs =
New ReportingService2005()
rs.Credentials = System.Net.CredentialCache.DefaultCredentials
Dim items() As CatalogItem = Nothing
Dim root As Node = New Node()
root.Text = "Root"
uwtReportFolders.Nodes.Add(root)
' Retrieve a list items from the server
Try
items = rs.ListChildren("/", True)
Dim j As Integer = 1
' Iterate through the list of items and find all of the folders and display them to the user
For Each ci In items
If ci.Type = ItemTypeEnum.Folder AndAlso (Not ci.Hidden) Then
Dim rx As Regex = New Regex("/")
Dim matchCnt As Integer = rx.Matches(ci.Path).Count
If matchCnt > j Then
uwtReportFolders.SelectedNode = 'cannot figure this out
j = matchCnt
ElseIf matchCnt < j Then
j = matchCnt
End If
Dim newNode As Node = New Node(ci.Name, "", "", "", "")
uwtReportFolders.SelectedNode.Nodes.Add(newNode) 'cannot figure this out
uwtReportFolders.Nodes.Add(newNode)
'addNode(ci.Name)
End If
Next
Catch ex As SoapException
Catch ex As Exception
End Try
End Sub
First of all.  I don't know if this is the best way to do this.  I am trying to avoid using the tables just is case the structure changes.
I cannot figure out how to set the selected node (again this may not be the best way to do it)  so that I can add the newest node to it.
Any suggestions??
Thanks...
