Hi all,
I am using paging and outlook groupby on the webgrid..
However when I do a groupby on any column I get a group for the currently active page..
for eg. if my page size is 5 and I group it up by lastname.If I have 20 records with lastname SMITH the group will show up as
LASTNAME:SMITH(5) on 4 pages..
How can I make it show the total datagrid summary instead of just the page summary. LASTNAME:SMITH(20)
Joel
Hi,,,
This functionality is not inherent with the grid..To achieve this in your GroupColumn event handler disable the LoadOnDemand=xml paging...Bind the grid and then turn it on again..
Here is the code snippet
this.WebGrid.DisplayLayout.LoadOnDemand = LoadOnDemand.NotSet;
this.WebGrid.Browser = BrowserLevel.Auto;
WebGrid.DataSource=dt;
WebGrid.DataBind();
this.WebGrid.Browser = BrowserLevel.XML;
this.WebGrid.DisplayLayout.LoadOnDemand = LoadOnDemand.XML;
I am looking for the GroupByRows property for the WebGrid control and I do not see it anywhere. I looked in .DisplayLayout but i only see the objects GroupByColumnsHidden, GroupbyRowDescriptionMask and GroupByRowStyle.
I am having the same problem as the original post. Basically I would like to have a groupBy column, but if i do that I lose the paging behavior, showing only the rows on the first page.
Can you provide me wih more information
Thanks and regards
DB
The GroupByRows have a property called "Text" that you can use to change the text to whatever you need.
