Hello I am redeveloping my web-aplication using the latest version of the Webgrid.I really have a big problem, on all of my pages i have a listview that is bind to a database to get a list of categories. Then I have a webgrid that display data based on the item selected in my listview. But for some reason each time I select an item in my list view, the listview completely disappear.If I remove the webgrid, then the listview does not disappear when I select an element.I made test by replacing the webgrid by a gridview and everything work fine.I really need you help on this because my entire web-application is based on those listview and webgrid.Thanks
This version of the toolset is no longer available for a trial download, so a license key is required to download.
If you have a registered key for NetAdvantage for .NET 2008 Volume 2 (or NetAdvantage Web Client or NetAdvantage Select for the same volume), you can download this version from the My Keys and Downloads page of our website.
If you have a key for NetAdvantage for .NET 2008 Volume 3 (or the other appropriate packages for this volume), but not for 2008 Volume 2, I suggest that you contact our Customer Service team, as they can better provide you with the options that are available.
I submited a support request. At the mean time could you give me a link to download the previous version (netadvantage 2008 vol2 CLR3.5).We need to keep working on our project without having to wait for you guys to fix the bug, so we hope that the previous version does not have this bug and we will be able to keep moving forward while you guys find the problem.Thanks
Please submit a support request, as I mentioned in my previous post. This sounds like it's probably a bug, though this is not certain. We'll need to look into this further to determine exactly what's happening, why, and what we can do to address it. The amount of research needed is best handled through our support systems, rather than over these peer-to-peer forums.
I alreally pulled half of my hair on that. The behavior is really easy to reproduce, put a webgrid on your page and then add a gridview or a Listview or a Datalist. Also add a button to reproduce a postback.Bind the webgrid and other item to whatever datasource and you will see that when you click on the button everything will disappear except the button and the webgrid.PLease let me know if you have any suggestion, this is really the center piece of all of my work.Thanks
This behavior doesn't look familiar to me, and I can't think of an explanation of why it would occur.
Can you reproduce this behavior in an isolated sample application? If so, then my best suggestion is for you to submit a support request and attach that sample to the request. A Developer Support Engineer will research your issue using this sample, and will work with you to reach a resolution.
