340
updatepanel and webgrid
Hi
I am having a problem with the webgrid (no ajax enabled) inside a standard (ajax) updatepanel.
the ultrawebgrid (filled using a datatable) shows to the user the customers A, B,C
After the user clicks on a button "Delete" (inside the updatepanel), I delete the customer A from the db and I force the ultrawebgrid's reload (getting again a datatable from the db and binding it again to the webgrid) so the grid should now show only the customers B and C, but it does not....It still shows customer A, B and C.
After the delete, the datatable has all the correct info, it means it contains only customer B and C.....so it is not a datatable problem.....
I tried using a webgrid column type "Button".....but I have the same problem....
Same problem If I use a WARP panel instead of a standard updatepanel
Also if I use a Webdialog inside the update panel....it does not show up clicking the button "delete"
If I remove the update panel...all works perfectly...but it is very slow......
Any help is kindly appreciated.....
  • 185
    Did you set the grid itself as an async trigger on the updatepanel its in?
  • 627
    Did you solve the problem?
    I'm facing almost the same issue with no solution so far...
    Thanks in advanced
    Maya
  • 45049
    Since this works correctly without an UpdatePanel (or WARP) involved, there's something not working correctly.  We'll need more information to determine whether this is a bug or if it's a problem with the approach you're using, and to resolve the issue in either case.
    Please submit a support request so that a Developer Support Engineer can assist you further.  If possible, please include a sample prject that we can run and debug that reproduces this behavior, so that we know we're testing the same code that you are.
