139
Client Side Event Getting Lost in WARP
Hello, I am trying to link up Header Click Event (Client Side) with my custom javascript function. The grid resides inside a WARP. I did that at compile time and it works perfectly fine. However after a single Asynchronous call, the grid looses the client side event. And any subsequent clicks on the header doesn't raise the event. Any ideas?
  • 45049
    I'm not sure what could cause this.
    Is the grid's built-in functionality otherwise working after the asynchronous callback?  If not, then a JavaScript error may have occurred that is preventing all JavaScript from running.  If the rest of the grid's functionality is working, then I would next suspect there's something about how you're connecting your JavaScript function to the event handler.
    My best advice is for you to submit a support request and attach a sample that we can run and debug that reproduces this behavior.  A Developer Support Engineer will use that sample to determine what's happening and what can be done to resolve the issue.
