60
Binding UltraWebMenu From DataSet
 Hi !
Please help me how to binding a UltraWebMenu from DataSet with struct "ID - ParentID". Thanks !
  • 175
    The formatting got screwed here is better version.
    private void LoadMenuItems()
    DataSet dsMenuItems = new DataSet();
    try
    //this method gets you the 2 datatables in the dataset
    GetMenu(ref dsMenuItems);
    dsMenuItems.DataSetName = "Menu";
    dsMenuItems.Tables[0].TableName = "MainMenu";
    dsMenuItems.Tables[1].TableName = "SubMenu";
    dsMenuItems.Relations.Add("RELATION", dsMenuItems.Tables[0].Columns["MAINMENUITEMID"],
    dsMenuItems.Tables[1].Columns["MAINMENUITEMID"], true);
    //populate the menu here
    if (dsMenuItems != null)
    UltraWebMenu1.DataSource = dsMenuItems;//.Tables[0].DefaultView;
    //UltraWebMenu1.Levels[0].TargetUrlName = "NAVIGATIONURL";
    UltraWebMenu1.Levels[0].ColumnName = "MAINMENUITEMNAME";
    UltraWebMenu1.Levels[0].LevelKeyField = "MAINMENUITEMID";
    UltraWebMenu1.Levels[0].RelationName = "RELATION";
    UltraWebMenu1.Levels[1].TargetUrlName = "NAVIGATIONURL";
    UltraWebMenu1.Levels[1].ColumnName = "SUBMENUITEMNAME";
    UltraWebMenu1.Levels[1].LevelKeyField = "SUBMENUITEMID";
    UltraWebMenu1.DataMember = dsMenuItems.Tables[0].TableName;
    UltraWebMenu1.DataBind();
    catch (Exception ex)
  • 175
    Here it is if you want to bind a dataset.
    DataSet
    try{
    GetMenu(
    GetMenu(
    GetMenu(
    ref dsMenuItems);
    "Menu";
    "MainMenu";
    "SubMenu";
    "RELATION", dsMenuItems.Tables[0].Columns["MAINMENUITEMID"], sMenuItems.Tables[1].Columns["MAINMENUITEMID"], true);
    "MAINMENUITEMID";
    "RELATION";
    "NAVIGATIONURL";
    "SUBMENUITEMNAME";
    "SUBMENUITEMID";
  • 60
    Verified Answer
     i have been used binding of UltraWebTree for Menu and it work fine.
    here is my DataTable with columns "ID - ParentID - Name" and a Relations as
    DataRelation dr = new DataRelation("re", ds.Tables[0].Columns["ID"], ds.Tables[0].Columns["ParentID"], false);
    and this is code for binding:
               //assign the datasource
                DataView dv = ds.Tables[0].DefaultView;
                dv.RowFilter = "ParentID=0";
                this.UltraWebMenu1.DataSource = dv;
                //set up the levels to use the relation
                for (int i = 0; i < 50; i++)
                    this.UltraWebMenu1.Levels[i].ColumnName = "Name";
                    this.UltraWebMenu1.Levels[i].LevelImage = "../../../ig_common/images/dir.png";
                    this.UltraWebMenu1.Levels[i].RelationName = "r1";
                    this.UltraWebMenu1.Levels[i].LevelKeyField = "ID";
                //databind
                this.UltraWebMenu1.DataBind();
                UltraWebMenu1.WebMenuTarget = Infragistics.WebUI.UltraWebNavigator.WebMenuTarget.HorizontalMenu;
