285
How to Find Specific Row?
I've got a webcombo that I'm filtering using selectWhere.  After I execute selectWhere, I'd like to select a certain value from the webCombo.  I can't quite figure out how though.  Here is what I've done so far.
1.  I tried doing a more selective filter, one which I know will only return one row.  My plan was to simply get the datavalue of that one row, but I can't get a reference to that "one" row.  Here is the code I was trying:
            var dataValue = igcmbo_getComboById("WebCombo1").getGrid().Rows.getRow(0).getCellFromKey("ColumnName").getValue();
    This code returns the value of the first row in the non-filtered list, instead of the filtered one. \
2.  I also tried spinning through the rows in the webcombo's grid looking for "my row".  The problem with this is that I've got EnableXmlHTTP on, so only the first 50 rows are available, and "my row" isn't in the first 50.
 Can anyone suggest a solution for me?
 Thanks in advance - John
  • 2254
    Take a look at this answer. It shows you how to detect when selectWhere() finished its job by intercepting the Ajax events raised internally
    AfterXmlHttpResponseProcessed(gridName) and the
    XmlHTTPResponseHandler(gridName, rowId, gridResponse)
     http://news.infragistics.com/forums/t/2841.aspx
    Once you know that selectWhere() has finished, then you'll be able to do whatever you like with certain values from the webCombo
  • 2254
    We need to know when the Ajax call made internally by  the selectWhere() JavaScript function finishes its job. You can see by stepping into the code with the debugger that the selectWhere() looks like this:
    this.selectWhere=function(where)
      var g=this.grid;
      if(g.LoadOnDemand!=3)
       return;
      g.Bands[0]._sqlWhere=where;
      this.updatePostField(this.getDisplayValue());
      var sortOrder=g._buildSortOrder();
      g.invokeXmlHttpRequest(g.eReqType.Custom,null,"combofilter\x02"+where+"\x04sort\x02"+sortOrder+"\x04displayValue\x02"+this.displayValue);
    Therefore if we knew when the Ajax call  finishes, it should be easy to select a certain value from the webCombo.
  • 2254
    I'm interested to find the answer to this question as well.
    Maybe this article can help you
    http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=8482
