We have set HeaderClick = "ExpandOnClick" but they neither expand nor contract on click in Safari.
Jay
Setting Browser target somewhere (ASPX or code behind) to "UpLevel" , should make it work fine in Chrome:
UltraWebListbar1.BrowserTarget = Infragistics.WebUI.UltraWebListbar.BrowserTarget.UpLevel;
Angel
Hello solutrian,
Have you found a workaround to make the ultraweblistbar work with safari?
I am very concerned with Infragistics products, this is the first time my company focus in safari browser compatibility, we do not have an explanation to our clients and we definitely need a solution.
Infragistics team:
I do really appreciatte any guide from you to resolve this, I have strong javascript/css/html knowledge, any direction on how to implement a workaround using the existing html generated code could help me. thank you very much for your support.
Yasel
Hello,Thanks for reporting this problem - I was able to reproduce it as well for both Safari and Chrome. Unfortunately for the time being Safari and WebKit are still not supported. We are doing our best to provide support for them, but this will take time. The link below shows environments and operating systems under which our products are tested and supported. Select your product from the list below to view support details. http://ko.infragistics.com/support/productstatus.aspx#SupportedEnvironmentsAlso at link below you can submit feature request:http://devcenter.infragistics.com/Protected/RequestFeature.aspx
Thanks.
