225
Exception when there are more than 440 Infragistic columns in a Web Grid
 When there are more than 440 number of columns in a Web Grid, the UI rendering fails as there is an Int32 limit that is passed.Is there hot fix for this problem?
 [ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
Parameter name: value]
   System.Web.UI.WebControls.Unit..ctor(Int32 value) +1153178
   System.Web.UI.WebControls.Unit.Pixel(Int32 n) +23
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.RenderHeaderStationary() +2002
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.RenderHeadingArea() +172
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.RenderTableFrame() +2270
   Infragistics.WebUI.UltraWebGrid.RenderDHTMLGrid.VisitObjects(HtmlTextWriter output) +1063
   Infragistics.WebUI.Shared.RendererBase.Render(HtmlTextWriter output) +16
   Infragistics.WebUI.UltraWebGrid.GridRendererBase.Render(HtmlTextWriter output) +477
   Infragistics.WebUI.UltraWebGrid.UltraWebGrid.Render(HtmlTextWriter output) +336
   System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121
   System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22
   System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +199
   System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +20
   System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +59
   System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +68
   System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +37
   System.Web.UI.Page.Render(HtmlTextWriter writer) +26
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2558
regards,
Rajiv.
Parents Reply Children
No Data
