460
WebGrid CSOM support for paging?
Does WebGrid have any support for paging on client-side? Looking at CSOM overview, I can't see any object which has to do with the Pager-object on server-side, nor any event like page-index change. Do I have to implement paging on client-side completely on my on from scratch?
 Best regards
  • 28464
    Yes, I played a bit with the Client Side Object model of the grid and could not find anything that fires on the client prior to paging. I even tried the generic MouseDown events - same results. Nothing of what I see listed here seems to do the trick.
    http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR3.5/html/WebGrid_Client_Side_Events_CSOM.html
    In addition, I see that probably something built-in may be working only for Ajax grid, please see the following forum thread for details:
    http://forums.infragistics.com/forums/p/1855/33184.aspx#33184
    Otherwise, maybe it will be possible to create custom paging (there is a sample available at the link below -> in the Grid -> Navigating & Selecting -> Custom Paging example):
    http://samples.infragistics.com/2008.2/webfeaturebrowser/default.htm
    and then manually control the HTML of the custom pager to invoke javascript event prior to going back to server for paging.
    Hope this helps.
