380
Combo box indicator in grid
I am embedding a combo box in my webGrid and all works as expected.
One request I am getting from my users is to indicate that a column in a grid is a combox box prior to them selecting the cell.  This would be very similar to how one would see a "grid" built dynamically using php.  Each row would contain a combo box and would be clearly visible as a combo box prior to a user selecting the cell.
 I am also noticing that it takes three clicks in a grid cell to get the combo box to drop down.  Seems like it should take only one, which is how a combo box off a grid reacts.
Any help on showing some type of indication would be appreciated.
  • 7694
    If  you  use the property  EditorControlID  combobox will appear only in editing time. In your case  you can use the  TemplatedColumn of UltraWebGrid and inside add WebCombo. Please take a look at piece of code below:
      <Bands>
                    <igtbl:UltraGridBand>
                        <Columns>
    <igtbl:TemplatedColumn Width="100">
                        <CellTemplate>
                            <igcmbo:WebCombo ID="WebCombo1" runat="server" Width="100">
                            </igcmbo:WebCombo>
                        </CellTemplate>
                    </igtbl:TemplatedColumn>
    Hope this helps.
