In my grid, I would like to have a delete button next to my add new button for deleting rows. Also, I'd like to use the delete key on the keyboard only for deleting contents of cells, not use it for deleting rows. Currently, I'm using automatic binding (using designer to create SQLDataSource and CRUD).
Is this possible to do?
I need this functionality because users may unintentionally delete rows when they only meant to delete contents of a cell.
You can use the client side event KeyDownHandler of ClientSideEvents and disable key “Delete” with JS code below:
<ClientSideEvents KeyDownHandler="Action" />
JS code:
<script type="text/javascript"> function Action(gridID, cellIDb, key) { if (key == 46) { return true; } } </script>
Also about the picture you can take a look at the link below:http://dotnetslackers.com/articles/aspnet/QuickGuideToImplementingTheNetAdvantageUltraWebGrid.aspx
Hope this helps.
