I am using a webgrid with subbands and a RowEditTemplate to edit a subband. I'm doing the recommended clientside script to fill the edittemplate and write it back to the corresponding row, so far this all works fine.
The problem is that when i use cell.setValue(...) on a cell that has a DateTime datatype, and the source of the new datetime is a WebDateTimeEdit, the datetime gets displayed in the cell in english format (MM/dd/yyyy) instead of the german format (dd.MM.yyyy) it had before editing.
How can i tell the cell in what format the datetime should be displayed and why is the format different before editing and after?
Cheers,
Alex
I found the solution in the following: Goto the Colums Collection in the band and set the Format to be "dd.MM.yyyy HH:mm:ss" - anything else had no impact on the displayformat.
Try giving cell's maskededit property (coding part) and give the format you want like dd.MM.yyyy.
Hope, this helps.
