245
Problem with WebTab and WebGrid inside
Hi, I have problem on a simple WEBTAB control (3 tabs) with 3 WebGrid inside (1 each tabs) using <ContentTemplate>.
When the page is loaded, with the first Tab (Tab1) selected, the Webgrid inside a Tab work fine.
But all other WebGrid (hidden, for now, in this view) not showing ROW if contains only ONE "records" (one row). When I try to change Tabs, I find the WebGrid empty with a header show in a middle height in a WebGrid Frame.
With MORE than one row, all working good.
It's important say that if I change "Selected Tab" on TAB 2, the WebGrid inside work fine with only one row, but the problem persist in all Webgrid hidden in Tab 1 and Tab 3.
I format ALL Colums of WebGrid by C# : (sample of "column format")
 Grid.Columns.Clear();
            UltraGridColumn Col;    //Column
            Col = new UltraGridColumn("XXXX", "XXXX", ColumnType.NotSet, "");
            Col.FieldLen = 30;
            Col.Width = Unit.Pixel(130);
            Col.AllowUpdate = AllowUpdate.No;
            Col.Hidden = false;
            Grid.Columns.Add(Col);
 --- ETC ETC -----------------------------------------------------
..and I add rows using this simple code: (sample of "Rows add")
            Grid.Rows.Clear();
            for (Int32 Rig = 0; Rig < _Recs.Count; Rig++)
                //Create ROW
                Grid.Rows.Add();
                //Pop Col
                for (Int32 Col = 0; Col < Grid.Columns.Count; Col++)
                    String KXDD = Grid.Columns[Col].Key;       //Codice Dato;
                    if (KXDD == "A06")
                        Grid.Rows[Rig].Cells[Col].Value = _Recs[Rig].ItemGet(KXDD); \\CheckBox
                    else
                        Grid.Rows[Rig].Cells[Col].Text = _Recs[Rig].ItemGet(KXDD).ToString();  \\Text
Anyone have same problem and find a solution?
