731
Please guide Related to WebGrid
this is my first post in this forum and my requirement is as follow...
in Webgrid i want to achieve functionality to enter some values may b 4 to 5 column then at the end of pressing enter in 5th column it should create new row with same functionality....
 how can i achieve this please guide.... or something like tutorial would be helpfull for me..
  • 3732
    To achieve the above functionality, some properties of the UltraWebGrid's DisplayLayout needs to be set. The following lines of code explains how to set the properties in code:
    this.UltraWebGrid1.DisplayLayout.AllowAddNewDefault = Infragistics.WebUI.UltraWebGrid.AllowAddNew.Yes;
    this.UltraWebGrid1.DisplayLayout.AddNewBox.Hidden = false;
    this.UltraWebGrid1.DisplayLayout.AddNewRowDefault.Visible = Infragistics.WebUI.UltraWebGrid.AddNewRowVisible.Yes;
    this.UltraWebGrid1.DisplayLayout.CellClickActionDefault = Infragistics.WebUI.UltraWebGrid.CellClickAction.Edit;
    To set these in design view, open the properties window for the Grid, then expand the DisplayLayout section and set these properties.
