I'm trying to loop through the rows of a grid. My function works fine when not grouped, but something is going awry when grouped.
I'm looping through the top level grid.Rows. On each row I check if row.ChildRowsCount > 0. Which it is on the second iteration.After that I have an alert showing me row.ChildRowsCount and row.getChildRows.length. The first is 4 but the second is 0.I also tried row.getChildRow(0), which is null.
Any help please?
Thanks for responding. I actually did get this working in my project.
My problem seemed to stem from the fact that I was hiding rows. Basically, I have 2 grids, and when they click on a row in the first grid, I show the rows in the second grid that are applicable, and hide the rows that are not. I was setting row.Element.style.display = "none", which seemed to confuse it. It knew the rows were there, because the childcount was right, but I couldn't access them. I modified my code to change the className on the Element instead, and it seems to work.
Although I might end up having to do a postback anyway, because it takes forever to loop through the grid if there are more than just a few rows.
No. Never did, I figured it must be something wacky about my project, and we just put a workaround in place. Did a full postback rather than javascript like I would have preferred.Let me know if you figure anything out, please. Good luck!
Did you ever find a solution for this? I am having the same problem.
Kerri
I think we need to take a closure look at this issue. Please submit your request @ http://ko.infragistics.com/support/default.aspx with our Developer Support Team. If possible, please attach a sample. This way we'll be able to help you more.
Think I found a bug? The script I'm running is not triggered from a grid event, it runs after a user action, uses igtbl_getGridById(ClientId).rows.
I do have client side handlers set up for MouseOver, MouseOut, and CellClick. After I saw your post, I tried it again, with the code to set the handlers commented out. Getting the same result.
