170
checking unchecking checkboxes of a row.
hello,
there is a ultraweb grid in which there are few columns having only checkboxes in them. There is a column among them which when checked(in any row) checks all the checkboxes in its row. so its basically a column("select all") containing checkboxes to check or uncheck a whole row of adjacent checkboxes in a row. the columns containing the checkboxes are not fixed like the other columns in the grid i.e they slide on the horizontal scroll.
i want the functionality of checking or unchecking the checkboxes of a row when a particular checkbox in that specific row is checked or unchecked.
i tried the DOM objects and their methods. i tried some of infra CSOM methods like igtbl_getRowByid which gave me the row in an object "row" but rows.cells[ or rows.getCell() did not work on that object
i tried with cellclickhandler clientside event to try to get the row and its column but i couldnt get the cells of the row or their element which are the checkboxes.
  • 28464
    Indeed, this turned out not so trivial. I tried myself and it took me several different scenarios until I got it right. The idea is to use the AfterCellUpdateHandler client-side event handler of the grid and then CSOM to locate checkbox elements and check/uncheck them. The caveat was the the handler was firing upon each checking / unchecking of checkboxes, ultimately leading to endless recursion / stack overflow.
    I was able to deal with that with a global "insideHandler" flag.
    Here is my approach:
            var insideHandler = false;
            function cellClick(gridID, cellID)
                if (insideHandler)
                    return;
                insideHandler = true;
                var cell = igtbl_getCellById(cellID);
                var checkBox = cell.Element.getElementsByTagName("INPUT")[0];
                for (var i = 0; i < cell.Row.cells.length; i++) {
                    var childCell = cell.Row.getCell(i);
                    var childCheckBox = childCell.Element.getElementsByTagName("INPUT")[0];
                    childCheckBox.checked = checkBox.checked;
        </script>
        <div>
        </div>
        <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Height="200px"
            Width="325px">
            <bands>
                <igtbl:UltraGridBand>
                    <addnewrow view="NotSet" visible="NotSet">
                    </addnewrow>
                </igtbl:UltraGridBand>
            </bands>
            <displaylayout  ClientSideEvents-AfterCellUpdateHandler="cellClick"
             protected void Page_Load(object sender, EventArgs e)
            DataTable dt = new DataTable();
            dt.Columns.Add("Check 1", typeof(Boolean));
            dt.Columns.Add("Check 2", typeof(Boolean));
            dt.Columns.Add("Check 3", typeof(Boolean));
            dt.Rows.Add(new object[ { false, false, false });
            UltraWebGrid1.DataSource = dt;
            UltraWebGrid1.DataBind();
    Hope this helps.
