731
Can any one help me in getting sum of Grid column??
i am facing problem i want to get sum of currency value at the bottom of grid i dont not want to use any button as infragisitic has used in sample codes neither webcalcmanager is usable in this situation
 i am entering values and i want to calclute sum at that time using javascript but ultrawebgrid is keep changing its id when i click from one to next cell when i am on active row then its id is _nr at the end and when i click on another row and then click back to last row its id gets change... like _2....
i am not able to place check of row id in such a situation is there any easy way to achieve this functionality????????????????
  • 28464
    I am not 100% sure I understand the whole situation in detail, but if you are rely on hardcoded IDs on the  client-side, this will probably lead to the problems you describe since there is no guarantee client IDs will be the same.
    You can use the client-side ID of the grid in the following way
    var clientID = "<%= UltraWebGrid1.ClientID  %>";
    HTH,
