The problem I am having is that I can't detemine which event to handle after the insert or why no data is being inserted.
The UltraWebGrid1_AfterRowInsertHandler fires when I hit the Add New Box button and this makes sense but should it be?? I think the grid is trying to insert into the database here but fails becaue the row is empty at that time. Shouldnt this event fire when I click off the new row? What actually fires on my new row after entering data is the UltraWebGrid1_TemplateUpdateCellsHandler. But this 'updates' the database and there is no record yet. (record has not been inserted yet.)
UltraWebGrid1_TemplateUpdateCellsHandler fires after clicking the Ok button on the row edit template. From within the UltraWebGrid1_TemplateUpdateCellsHandler event I issue a postback but nothing gets inserted into the database. And the sqldatasource1_inserted event is never fired.
If I remove the UltraWebGrid1_TemplateUpdateCellsHandler and use an imagebutton to cause postback the record still is NOT inserted.
Updates and Deletes work fine.
What am I missing?
I believe this question has just been answered in the following forum thread:
http://forums.infragistics.com/forums/t/20703.aspx
Is this working fine for you?
