310
Problem with Sorting and then Row Selection
I'm having a problem with the UltraWebGrid when I sort a column and then try to select it using a button in a column with a Type of Button. If I sort a column and then select it with the button in that row the CellEventArgs in the ClickCellButton Event seems to contain the data for a different row. This is happening using both Client Side and Server Side sorting. Everything works fine though when I apply a filter to a column and select a row. Any ideas on what could be causing this?
<igtbl:UltraWebGrid ID="findInventoryTransferUltraGrid" runat="server" Browser="Xml"
OnInitializeDataSource="FindInventoryTransferUltraGrid_InitializeDataSource"
OnClickCellButton="FindInventoryTransferUltraGrid_ClickCellButton"
StyleSetName="Caribbean" EnableCrawlerDetection="False">
<Bands>
<igtbl:UltraGridBand>
<Columns>
<igtbl:UltraGridColumn AllowGroupBy="No" AllowRowFiltering="False" BaseColumnName="Select"
CellButtonDisplay="Always" Key="Select" NullText="Select" Type="Button" Width="6%"
FilterOperatorDefaultValue="Contains">
<Header Caption="Select" />
</igtbl:UltraGridColumn>
<igtbl:UltraGridColumn BaseColumnName="Id" Key="Id" Hidden="True">
<ValueList DataMember="Id" DisplayMember="Id" Key="Id" ValueMember="Id" />
<igtbl:UltraGridColumn BaseColumnName="OrderNumber" Key="OrderNumber" Width="10%"
<ValueList DataMember="OrderNumber" DisplayMember="OrderNumber" Key="OrderNumber" ValueMember="OrderNumber" />
<Header Caption="Order Number" />
<igtbl:UltraGridColumn BaseColumnName="Source" Key="Source" Width="13%"
<ValueList DataMember="Source" DisplayMember="Source" Key="Source" ValueMember="Source" />
<Header Caption="Source" />
<igtbl:UltraGridColumn BaseColumnName="Destination" Key="Destination" Width="13%"
<ValueList DataMember="Destination" DisplayMember="Destination" Key="Destination" ValueMember="Destination" />
<Header Caption="Destination" />
<igtbl:UltraGridColumn BaseColumnName="Title" Key="Title" Width="14%"
<ValueList DataMember="Title" DisplayMember="Title" Key="Title" ValueMember="Title" />
<Header Caption="Title" />
<igtbl:UltraGridColumn BaseColumnName="TransferType" Key="TransferType" Width="7%"
<ValueList DataMember="TransferType" DisplayMember="TransferType" Key="TransferType" ValueMember="TransferType" />
<Header Caption="Type" />
<igtbl:UltraGridColumn BaseColumnName="Status" Key="Status" Width="7%"
<ValueList DataMember="Status" DisplayMember="Status" Key="Status" ValueMember="Status" />
<Header Caption="Status" />
<igtbl:UltraGridColumn BaseColumnName="Placed" Key="Placed" Width="5%"
<ValueList DataMember="Placed" DisplayMember="Placed" Key="Placed" ValueMember="Placed" />
<Header Caption="Placed" />
<igtbl:UltraGridColumn BaseColumnName="DateCreated" Key="DateCreated" Width="15%"
<ValueList DataMember="DateCreated" DisplayMember="DateCreated" Key="DateCreated" ValueMember="DateCreated" />
<Header Caption="Date Created" />
</Columns>
</igtbl:UltraGridBand>
</Bands>
<DisplayLayout AutoGenerateColumns="False" Name="UltraWebGrid1" RowHeightDefault="25px"
StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed" Version="4.00" AllowSortingDefault="OnClient"
HeaderClickActionDefault="SortMulti" LoadOnDemand="Xml" RowSelectorsDefault="No"
SortCaseSensitiveDefault="False">
<FrameStyle BorderColor="#001060" BorderStyle="Solid" BorderWidth="1px" Cursor="Default"
Font-Names="Verdana" Font-Size="8pt" Width="100%">
</FrameStyle>
<RowAlternateStyleDefault BackColor="#E9E9F7">
<BorderDetails ColorLeft="233, 233, 247" ColorTop="233, 233, 247" />
</RowAlternateStyleDefault>
<Pager AllowPaging="True" PageSize="15" StyleMode="Numeric">
<PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<BorderDetails ColorLeft="White" ColorTop="White" />
</PagerStyle>
</Pager>
<EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
</EditCellStyleDefault>
<HeaderStyleDefault BackColor="#2B64A7" BorderColor="Black" BorderStyle="Solid" ForeColor="White">
<BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" />
</HeaderStyleDefault>
<RowStyleDefault BackColor="#C7D5E8" BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px"
Font-Names="Verdana" Font-Size="8pt">
<Padding Left="3px" />
<BorderDetails ColorLeft="199, 213, 232" ColorTop="199, 213, 232" />
</RowStyleDefault>
<SelectedRowStyleDefault BackColor="#0A75F0" ForeColor="White">
</SelectedRowStyleDefault>
<AddNewBox>
<BoxStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
</BoxStyle>
</AddNewBox>
<ActivationObject BorderColor="Black" BorderStyle="Dotted" BorderWidth="" AllowActivation="False">
</ActivationObject>
<FilterOptionsDefault AllowRowFiltering="OnServer" FilterUIType="FilterRow" FilterComparisonType="CaseInsensitive">
<FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
Font-Size="11px" Width="200px">
<Padding Left="2px" />
</FilterDropDownStyle>
<FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
</FilterHighlightRowStyle>
<FilterOperandDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid"
BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
Font-Size="11px">
</FilterOperandDropDownStyle>
</FilterOptionsDefault>
</DisplayLayout>
</igtbl:UltraWebGrid>
