Sample application for webgrid insert,update,delete using dynamic controls How is it possible?
Thanks. Its uesfull. i understood the concept thru samples.
Yes -- but the original example which I showed you and the samples are really our start-up examples and this is what we generally use as well. Maybe in addition to that, you can check out our online documentation here:
http://ko.infragistics.com/support/documentation.aspx#OnlineDocumentation
i saw that already. But i need that tuff to understand. I need that grid Insert,Delete,update controls in each rows, when i click add, edit or delete
keys.that working properly like ASP.net's Grid view updation thru JAVA Script Coding. First time i am using ultra web grid. Thatz the probs. I
need to understand clear abt that concept.
This is pretty much the same -- I mean the actual physical way to access the datasource does not really matter -- it can be stored procedure, dynamic DataTable, LINQ, anything -- you just need to follow the general logic of the sample.
If this is not enough, I suggest going through the samples we have for WebGrid here:
http://samples.infragistics.com/
There are plenty of atomic examples, including ones for data manipulation.
Hope this helps.
Thanks for kind reply.but what i feel is we just load a SQL table on that ultra webgrid on dynamic.. then how to edit, insert or delete in dynamic thru sql command not using stored procedure. to be just implete fully coding based..will u help me?
