I have an UltraWebMenu:
<ignav:UltraWebMenu TopAligment="Center" ID="uwmTopMenu" runat="server" Width="900px" JavaScriptFilename="" JavaScriptFileNameCommon="" BorderWidth="0" ItemPaddingTop="0" ItemSpacingTop="0" ItemPaddingSubMenus="0"> <%-- BackgroundImage="~/CibtImages/TabHeaderBorders/tab_header_corners_dkblue.gif" --%> <SeparatorStyle Width="2px" BackColor="Black" ForeColor="Black" /> <DisabledStyle Font-Size="8pt" Font-Names="MS Sans Serif" ForeColor="Gray"> </DisabledStyle> <Levels> <ignav:Level Index="0" /> </Levels> <ExpandEffects ShadowColor="LightGray"></ExpandEffects> <IslandStyle BackColor="#DADADA" ForeColor="Black"> </IslandStyle> <HoverItemStyle BackColor="#001A69" Cursor="Hand" ForeColor="White"> </HoverItemStyle> <ItemStyle Cursor="Default"> <Padding Bottom="4px" Left="4px" Right="4px" Top="4px" /> </ItemStyle> <Items> <ignav:Item Text="Home" TargetUrl="/home.aspx"> </ignav:Item> <ignav:Item Text="Visas" TargetUrl="/Visas.aspx"> </ignav:Item> <ignav:Item Text="Passports" TargetUrl="/Passports.aspx"> </ignav:Item> <ignav:Item Text="Service Directory" TargetUrl="/ServiceDirectory.aspx"> </ignav:Item> <ignav:Item Text="Global Cell Phones" TargetUrl="http://www.globalphoneworks.com/home.aspx" TargetFrame="_blank"> </ignav:Item> <ignav:Item Text="Status Check" TargetUrl="/onlinestatuscheck.aspx"> </ignav:Item> </Items> <%-- <SeparatorStyle BackgroundImage="CibtImages/pix_c4c4c4_h20.gif" CustomRules="background-repeat:repeat-x; " BorderStyle="Solid" BorderWidth="5px" BorderColor="Black" />--%> <MenuClientSideEvents InitializeMenu="" ItemChecked="" ItemClick="" SubMenuDisplay="" ItemHover=""></MenuClientSideEvents> </ignav:UltraWebMenu>
Why are the separator bars between the menu items not showing, despite that I have set the <SeparatorStyle ... /> tag? I would like separator bars of 1 pixel width of black color to show up between the items. Thanks.
Btw, this is the site I'm trying to put use the UltraWebMenu on: www.cibt.com.
Emad
Is there a solution for this? I have the same problem except with images as the separator.
This is the correct phone number. We've been receiving phone calls today successfully around the time of your post, which makes me suspect that your call simply never made it to our systems.
If you're in North America, you can also contact Developer Support toll-free at the following number: (888) 448-0097
Please give me the exact phone number of your developer support department. I tried (609) 448-2000 which was listed at http://ko.infragistics.com/corporate/contactus.aspx#ContactUs and all I get are beeps. Thanks!
You are right, I reproduced your issue and found same behavior.I believe at this point it is best to contact our Developer Support department directly - they can be reached athttp://ko.infragistics.com/support/
