I am working on a project for display general ledger summary, which requires me to display a web page with editable Ultra Web Grid which has a minimum of 1400 rows and maximum of 1700 rows with 16 columns in IE 6.0.
This page should have the functionality of Group By, cut, copy and paste.
I have implemented the above mentioned features, but when I try to use them the IE and the entire grid works really slow.
For example:
Retrieving the data takes only about 3 to 4 seconds.
My requirements are such that, I not able to using paging feature. The desired output should look like a balance sheet.
Can someone please advice, if using Ultra Web Grid would be the correct approach for the above mentioned scenario?
Thanks in advance.
Kind Regards,
Amit Shah
Hi Rumen,
Thanks for the advice, much appreciated. I will try the above mentioned suggestion.
Alternatively, I might make this application as a windows application using Ultra Win Grid. I have seen some examples provided by Infragistics and they work fine with high volume of data.
Thanks once again.
Hello Amit,
Indeed, performance has always been a commonly discussed topic here in forums -- that is why we have a great collection of resources on performance that is already available.
For a start, please check out this post for performance suggestions (and actually, the whole thread is very useful)
http://forums.infragistics.com/forums/p/14306/52885.aspx#52885
For grouping specific issues, please check out this post:
http://forums.infragistics.com/forums/p/3245/17711.aspx#17711
and finally, you can see a lot of performance related documentation topics in our online help here:
http://ko.infragistics.com/support/documentation.aspx#OnlineDocumentation
Hope this helps.
