Good Afternoon All
I have a Following code that i want to use to Disable a Cell in a Ultragrid based on the Arraylist value.
try
//Create an Instance of a BLL Class
//Save the Selected Value in the Session Variable
//Get the Final Pattern and Store it in a Local Variable
Final_Pattern = obj.Disable_Grid_Contents(Subject_Pattern);
//Create a Array and Split the Contents of the String with an empty Space and Assign it to the Array
//Create an Arraylist onject
//Add the Contents of the String StrS to the Arraylist
strsList.Add(s);
* Disable the Cells that have the Value*/
UltraGridRow row = new UltraGridRow();
I cant use the Enabled and the Visible Property.
Cool :) Forum search is indeed starting to get a very powerful tool, with more than 65,000 threads already. Please, let us know if you need additional information.
You Just Posted The thread we are working on
Once you get an instance of an cell, you can set the cell.AllowEditing property to No, I think this will get you what you need. There is a great thread on that here:
http://forums.infragistics.com/forums/t/21000.aspx
