how can I make the Row edit template pop up after clicking on the Add New Box without having to click on the new empty row?
If I try to do this in the UltraWebGrid1_AfterRowInsertHandler event using row.editRow() method it tries to update the record.
There is problem when ur grid is absolutely empty and you try to add rows using the above concept. The controls inside the Row Edit Template doesnot render properly.
Hi Rajib,
Let me know if you need any further assistance with this matter.
Bhadresh
Using the link mentioned above by Tom (http://help.infragistics.com/NetAdvantage/ASPNET/2010.1/CLR3.5/?page=WebGrid_Using_Row_Templates.html ) I have created a sample. I was able to show the popup row edit template by modifying the code you have provided as follows:
var grid = igtbl_getGridById("UltraWebGrid1"); var row = grid.Rows.getRow(0); row.editRow();
Please modify the code in your application and let me know if you need any further assistance with this matter.
var grid1 = document.getElementById("ctl00_PageContent_grdbatchs");
var grid2 = document.getElementById("ctl00xPageContentxgrdbatchs");
var
grid3 = igtbl_getGridById("ctl00_PageContent_grdbatchs");
var grid4 = "ctl00_PageContent_grdbatchs";
igtbl_addNew(grid1, 0);
row.editRow();
I have tried with the grid1, grid2, grid3 and grid4 and I am not able to create a new row or open the RoweditTemplate. Please advice.
Looks like you are on the right track. All you need to do now is to create a Row Edit Template that represents the fields that you want to show in the popup RowEditTemplate that shows.
Check out this topic:
Tom
