145
Row expanded for a particular value
I have 2-tiered hierarchical webgrid.
I want to expand only one parent row along with all its child row depending on a particular value in the parent row.
For eg:
ID1       Name1       Salary1      Address1
           ChildName1        DOB1
           ChildName2        DOB2
ID2       Name2       Salary2      Address2
           ChildName1        DOB1
If Parent ID = 1, expand parent and childrows for Parent ID 1
 Is this possible?
  • 80
    I do something similar with my grid.  In the grids InitializeRow event, if there is a certain value in the row, then I will change the color of that row.  Yours would look something like this...
      Protected Sub ugYourGridName_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles ugYourGridName.InitializeRow
        If Not (e.Row.Cells Is Nothing) Then
          If e.Row.Band.Key.ToUpper = "ParentBandName" Then 'This would be the name you have given the parent band.
        'You can also call it  by it's index - If e.Row.Band.Index = 0 Then
            If e.Row.Cells.FromKey("ColumnName").Text = "1" Then 'ColumnName is the name of the column whose value needs checked
              e.Row.Expand(True)
            Else
              e.Row.Expand(False)
            End If
         End If
      End If
    End Sub
    Hope this helps,
    Rosemary
