I have two tables, see below,
Table one
userid name phone
001 albert,oh **********
002 Kim,chale **********
Table two
date
2008-02-03
2008-02-04
2008-02-05
2008-02-06
Could I create web grid looks like:
userid Name Phone 2008-02-03 2008-02-04 .....
If there's no relation then you really have no choice but to manually update.
Have fun with that one. :-)
exactly, if we haven't another way. I have to hard code to update database table. By the way, these 2 tables dont have relation.
Thanks Robert.
But how are these 2 tables joined together or are they not joined at all??? Do you have a PK on each table that is a 1-1 relation?
Look into joining your tables through the use of PIVOT since your trying to do a cross tab type report.
You might not be able to use the SqlDataSource intrinsic update methods though. You will have to capture the update event and manually update the database. Just handle the UpdateRow event:
Protected Sub UltraWebGrid1_UpdateRow(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles UltraWebGrid1.UpdateRow End Sub
we can write store procedure using CURSOR, add column one by one. column name is 2008-02-02,2008-02-03,...
How are these 2 tables joined together? AllI see is a date in the one?
