340
No Data to Display
I am having a problem with using ultrawebgrid.  When I set the DisplayLayout to
AutoGenerateColumns
="True" the data displpays fine when I set it to false I get No Data to Display.
Binding is happening ok.
columns are defined with correct key
igtbl:UltraGridColumn HeaderText="" Key="DrawNum" Width="200px" BaseColumnName="DrawNum">
I took off the isBound="true" tag that I saw in another post here with a similar issue.
still not displaying data?
any ideas?
  • 7694
    Verified Answer
    This column is not bound and no have data. You have to  sure is bind to data source.
    Unbind column:
    <igtbl:UltraGridColumn HeaderText="" Key="DrawNum" Width="200px" BaseColumnName="DrawNum">
                            </igtbl:UltraGridColumn>
    Bind column:
                            <igtbl:UltraGridColumn BaseColumnName="CustomerID" IsBound="True" Key="CustomerID">
                                <Header Caption="CustomerID">
                                </Header>
    Please take a look at the picture below:
    Hope this helps.
